DickDV
I haven't seen anything that warrants a VFD. It's a ridiculously expensive way to get a fast stop if you don't need variable speed for the terminal velocity.
Without a VFD, I'd look into an oversized DC injection brake triggered by an Across-the-Line starter with a modular mechanical brake module added if the DC stop isn't fast enough.
VFD's are intended for applications where you want to vary the end speed and centrifuges generally run up to the same speed on every cycle.
