Drive With Scanport
nptechnoserve
Oct 2005
West Bengal
We are using Allen bradley 1397 Drive with "scanport" and SLC 5/04 and scanner module 1203-GD1 for communication with drive.
SLC 5/04 <---> 1203-GD1 <----> 1397 DRIVE
Now we want to replace 1397 by any other make of Drive Which is not having "Scanport" How we can do the retrofit.
Please advice immediately if any one know the solution.
Regards
P. K. Das
It is better to post this in the main Forum instead of in this "test post" area.
SCANport is a Rockwell Automation proprietary technology and there are no third-party drives that have that type of interface. It is partially compatible with Rockwell's new "DPI" protocol.
Because you are using an SLC-500 I would install a 1747-SDN DeviceNet scanner and buy a drive equipped with a DeviceNet interface.
Hi guys, I need help with position control using a Veichi AC Servo Drive model SD600A1-T2-2R2. How do I know how many pulses for it to rotary 1...
68
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
338
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
87
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
68
Hello everyone, my son and I are working on building a metal lathe. I been waiting for a motor/speed controller donor from a treadmill. I finally...
69
