DVB Sv plc with kepware ex opc server via rs485
zezo
Nov 2013
Csiro
Thanks for this valued information
I’m using converter form usb to rs485 and try to connect delta dvb sv plc to opc server kepserver ex and used the same setting specified at the manual on delta plc site but it read almost zero for all input and output even it 1 and i used the adress in modbustable….
and i can connect the plc to wplsoft via converter rs485 with no problem that mean converter works will as i guess……
Now where is the problem between opc server and plc?
Can any body help me?
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
26
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
58
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
53
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
50
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
61
