edwardeduful
Dear All,
Please I am having a challenge upgrading an E3 plus relay 193-EC3 (9-45 Amps) to 193-EC3 (18-90 Amps).
I doing this using a 193-DNENCAT via ethernet web browser.
The device is node 1 under the DNENCAT and I have assigned a name to it under the device identity.
The challenge now is electronic key mismatch error.
Anytime I try to remove the existing 9-45amps relay from the scanlist and save/configure I get an error.
‘’An error occurred while auto configuring the scan list’’
‘’Could not save data because there is an active class1 connection’’
Even if I remove the devicenet plug from the E3 plus relay, it gives me the same error again.
Please can you assist on how to go about it.
Thanks,
Thanks,
