earthing checking method on PLC
harrydeharry
May 2008
Delhi
237
Dear All,
One of our customer wants to measure the earth condition 24X7 wants us to show in on its SCADA, I never heard anything which can measure the earth online... any body has any suggestion regarding this...
thanks in advance (system S7-300)
If anyone can answer whether or not this can even be done (and I doubt it), it is Mike Holt. His site is easy to find. If it can be done, Holt will know what equipment is needed. Then you can figure out how to interface it to a PLC/SCADA system.
Last time I did an earthing check on a PLC installation I used a multimeter on the ohms range, so if you could get an instrument that reads ohms and can get that value into the PLC you should be OK.
Alan
We continuously monitor earth connections on trucks while they are delivering raw materials to our plants. We use earth monitoring units made by FDB Electrical Ltd who specialise in this type of application. They may be available in your region. Try http://www.fdb.uk.com/
Andy:
Are you not simply measuring the resistance between the truck and a known ground? Essentially, making sure the earthing lead stays connected, right?
Is that what the OP is asking? To monitor the earthing connection of a PLC chassis? I thought the original question was how to monitor the "viability" (for lack of a better word) of the actual earth connection of the facility.
Tricky question.
Hi. Hopefully someone here will know the name of the tool that is used to remove paint for an earth connection. Looks like a holesaw but the teeth...
2,608
Hi all, I'm currently in China to commission a job, and there are four large Danfoss FC102 VSD's (~200kW) which have been installed by the local...
4,605
This isn't a PLC question but I knows that members of this forum have many and varied skills and experience. Two of my current projects are...
2,580
Hi. Has any one here seen of or heard of a tool that is used in a drill to remove the paint from a panel before an earth lug is bolted to it...
3,491
Dear All I am attaching a word file where as I have described the Earthing system followed by our co. I am presently commissioning these panels &...
7,505
