Easybuilder Pro 8000 and Address Tag Library
sparkie
Nov 2014
KS
1,148
So as mentioned in my earlier thread, I'm trying to map out modbus values from a P2000 PLC from AD. I have all of my related tags set up in arrays of values, and I was hoping to read a range of coils, or read the value to a tag as a word and then pick out the bits I need from there. I've spent a few hours trying to figure this out and I'm a bit stumped.
I'm also not sure how their address column in this editor functions. It seems to give a data type and address, but I'm stumped here and can't seem to find any more detailed documentation on the subject.
I was hoping to avoid individually reading each single coil from the PLC register, as that would be a LOT of reads.
Edit: It is seeming to me that I add each individual coil with the 0x_multi_coil and if they are sequential addresses it will read them that way.
Since I can't edit, it seems that read multi coils instruction reads 16 bits, so when addressing your device and using read multi coil from this HMI, you just set your coils up in increments of 16 bits.
I have EB Pro installed on windows 11, I can open an existing project and edit but when I got to parameters tab and open page I get the hourglass...
62
Hi, I would like to know if it is possible to modify the properties of an object via a macro? For example I have a value of 100, via conditions...
871
Hi, I'm an intern student engineer and I'm tasked with creating a HMI for a control system in EBPro. I need to make an object (motor) which has...
1,782
Hello everyone Im Newbie to Easybuilder and im designing and HMI application where I gotta display a warning message in a pop up window...
1,810
I am banging my head trying to get EB Pro to convert simple math expressions. Ex: 1 Pump conversion coming from a SCP instruction O0 1.1 value...
1,873
