Easybuilder Pro - Show pop-up
Hydroplant
Jul 2016
France
Hello !
I will try to explain you my problem.
I'm doing a Easybuilder pro MMI. I created an alarm list object and a display to show all the new PLC's defaults.
They ask to me to open a pop-up form when a new default is detected. The pop-up have to show the name of the default, the date and hour of apparition.
I haven't find anything on this subject on easybuilder. I tried to do a VB macro but I don't know the function do show a form (Form.Show() doesn't work)
How can I make that ?
I just want to catch the last default on the alarm list and show it on a pop-up.
Thank you a lot. :)
Thanks for your answer.
I read the paragraph but unfortunately it doesn't help me...I created the pop-up window. The thing I don't succeed is to open it when a new alarm is detected.
Any VB developpers who can help me ?
I think the closest thing that you can use is the bit address LB-9043 (unacknowledged events exist).
If you combine that with the Indirect Window object you could show a popup when there are unacknowledged alarms.
It would stay open until alarms are all acknowledged.
Have a look at chapter 22 System Registers; and in particular 22.3.9 Event Log
If I am following correctly,
The popup to which you are referring is displayed upon the acknowledgement of an alarm defined in alarm log and displayed in the alarm object display. The alarm object display must be placed on a window for the alarm to be displayed before it can be acknowledged.
In order to make the alarm display object popup,
1. place the alarm object display (or any objects that you would like) on a new window
2. place a direct windows object in the common window, the read address is a bit set when the alarm is triggered by the plc or by the notification field in the event log object and the attribute is the window no. of the alarm window you wish to popup corresponding to the alarm
Hope this helps
Ken
Hi, and thanks for your answer.
I did all what you say, I can't make any tests for the moment but I will when I will get the PLC ;)
I have also set an alarm scroll list in the pop-up window to show the name of the last alarm. I don't know if it works.
Thanks to all !
hello Hydroplant, i also need that function, did you do it?
its a pitty that they dont include this as another brands
thanks in advance
I have EB Pro installed on windows 11, I can open an existing project and edit but when I got to parameters tab and open page I get the hourglass...
66
Hi, I would like to know if it is possible to modify the properties of an object via a macro? For example I have a value of 100, via conditions...
874
Hi, I'm an intern student engineer and I'm tasked with creating a HMI for a control system in EBPro. I need to make an object (motor) which has...
1,793
Hello everyone Im Newbie to Easybuilder and im designing and HMI application where I gotta display a warning message in a pop up window...
1,817
I am banging my head trying to get EB Pro to convert simple math expressions. Ex: 1 Pump conversion coming from a SCP instruction O0 1.1 value...
1,877
