Easybuilder Pro with Allen Brandley
manin
Jan 2015
Athens
37
Hello, I am trying to connect Weintek monitor with Allen Bradley Micro 820,
with ethernet interface.
I have downloaded a simple program to plc.
In easybuilder I have tried all ethernet options, but I have not managed to make the communicate.
In Plc connection guide, in DF1 ethernet IP, I see that PLC must have station number 1, but in RSLinx I see that the plc has 253, but I can't change it.
Neither in plc, or in monitor...
Any ideas?
Thanks in advance :)
Download the PLC Connection Guide from Weintek here.
Headline on page 941:
Rockwell Micro850 (Ethernet) - Free Tag Names
Supported Series: Rockwell Micro820/850 Ethernet Module.
I had already downloaded the guide, and tried this option, but I was doing something wrong...
Now it worked..
Thank you very much :)
Now it worked..
Telling the forum what it is you were doing wrong, or how you got it working may help someone else in the same situation.
Hello, I think that I imported wrong the variables, and I did not see any activity. All the other settings are fixed...
I am sorry for the mess, but I am trying to find out many things (Rockwell, FAtek, PID, Weintek) in small time and I am a little frustrated...
Thanks for all the help I get!!!
I have EB Pro installed on windows 11, I can open an existing project and edit but when I got to parameters tab and open page I get the hourglass...
62
Hi, I would like to know if it is possible to modify the properties of an object via a macro? For example I have a value of 100, via conditions...
871
Hi, I'm an intern student engineer and I'm tasked with creating a HMI for a control system in EBPro. I need to make an object (motor) which has...
1,786
Hello everyone Im Newbie to Easybuilder and im designing and HMI application where I gotta display a warning message in a pop up window...
1,810
I am banging my head trying to get EB Pro to convert simple math expressions. Ex: 1 Pump conversion coming from a SCP instruction O0 1.1 value...
1,874
