Easybuilder rotation question
PLC Pie Guy
Jun 2013
Halifax
1,144
Easybuilder Pro. Loving it, but I can't figure out how to simply rotate an object. I don't mean with animation, or based on value. Simply put a picture, or an bit lamp object on the screen that is rotated 90* from what is was in the library.
What am I missing? The manual has left me blank on this one.
EasyBuilder Pro does not currently support a feature to rotate static images within the development environment.
However; you may add any image to your library you wish to create. So you can export the image you wish to rotate into any photo editor, rotate it, and import the image into the image library for use.
How to create Graphic Images with Weintek EasyBuilder Pro Picture Libraries .jpg .bmp .gif .png: https://www.youtube.com/watch?v=mtoLA5AmxUw
Hope this helps,
Weintek USA Support
To be honest I'm not sure why it wasn't included from the start. However; I'm told our developers are planning to add it in.
Weintek USA Support
Hi Weintek USA! Welcome to the Forum, happy to have you aboard.
"Why? Why? Why?" PlcPieGuy, I can now no longer think of the name Weintek without replacing it with Why'ntek. Thanks!
I like how your biggest complaint is you have to use an image editor to rotate images (30 second workflow). When I compare it to some of the complaints I've had with HMIs over the years...
Speaking of rotating, one of my colleagues rotated the screen on another person's computer before they got in. They were totally confused and did not know how to fix it, until they searched up the keyboard shortcut on their phone, hahahaha. Good ole computer tricks!
(Ctrl + Alt + arrow key, although it's not working on my windows 10 for some reason)
OK, who else has tried the crl+al+ arrow and it hasn't done anything (win10)
:nodi:
Microsoft answer to the question.
This hot key is a feature of your graphics driver. Newer versions of it discontinued use of these hot keys. You may check this option if it is still available by pressing Ctrl + Alt + F12 > Options and Support > Hot Key Manager. As an alternative, you may switch your screen orientation by following the steps provided by Allan Mej.
I have EB Pro installed on windows 11, I can open an existing project and edit but when I got to parameters tab and open page I get the hourglass...
62
Hi, I would like to know if it is possible to modify the properties of an object via a macro? For example I have a value of 100, via conditions...
871
Hi, I'm an intern student engineer and I'm tasked with creating a HMI for a control system in EBPro. I need to make an object (motor) which has...
1,784
Hello everyone Im Newbie to Easybuilder and im designing and HMI application where I gotta display a warning message in a pop up window...
1,810
Greetings, Having a weird issue with an older Maple Systems 5070 HMI for a customer. We uploaded the configuration using EasyBuilder 5000. They...
1,718
