Elau epas-4
Nathan@ISL
Sep 2010
sheffield
Hi all,
I'm working on a system controlled by ELAU EPAS-4 software, and before I start squirting code into it I obviously need to ensure the version I have matches the online code. The problem is that it seems that you can't compare the project on your laptop to that on the controller directly, and you can't go online to the controller (to drag the code out) unless you have a program loaded on the laptop, we've even removed the card from the pacdrive and imaged it but it isn't the correct file extension(.pro). PLEASE HELP!!!
:unsure:
No problem, i've sorted it!!!
(y)
Hi Nathan,
I hope you will receive my reply even if this was posted 8 years ago...
How did you "drag the code out" of your controller? Tell me how you sorted this out please.
Hello Guys " Good Day " I would like to ask if you had encounter some error regarding with the EPAS-4 V24 Software. I had a program and I opened...
4,946
Hello, I have a project which is missing a library. Somebody maybe got this library for me? this is the library...
3,698
Hi everyone! I need CDkey for EPAS-4 v16. If you have it, help me, pl. 🍻
2,602
If i have project file , but i forgot password . please tell me how i can open that project .please help me . Thank you !
4,299
Our Client has a production line which is controlled by a Elau PacDrive C200 PLC networked via Profibus to its IO which is mostly Siemens ET200...
4,641
