Elau MAX-4 beeping
Oct 2015
Amsterdam
Hey Guys,
I have received an Elau MAX-4 motion controller, and it beeps :unsure:
When I try to connect via serial 232 and/or ethernet in EPAS-4 v24, I get nothing.
The ''power'' and ''bus err'' LEDS are constantley burning, right after power up.
Is it missing its Firmware?
Any help would be appreciated!
Greetings,
Okay thanks for the reply,
It does not explane why I can't connect with the motion controller?
The beeb continues for hours, while a good module just beebs 3 or 4 times.
In the manual they talk about the LED status, however no audio signal status.
Greetings,
hi everybody. i try conect whit max-4 and PacDrive Diagnostics 2.1 but i can´t do. i follow ok steps as next link video but in second 0.41 is my...
1,661
:beerchug:Hi everyone! The issue is that I have a machine with a PLC ELAU MAX-4 and can’t upload program from PLC. (I need to do some changes.)...
8,173
Not having a lot of luck finding the EDS file that will reconize The Elau Max-4 with Devicenet. RSNetworx for device net doesn't reconize the...
2,549
Hello, The issue is that I have a machine with a PLC ELAU MAX-4 modules and a WAGO PROFIBUS, I monitor some of this data with a PLC SCADA, ELAU...
7,762
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
71
