Electrically operated valves ?
milmat1
Aug 2005
North Carolina
209
I have an application where a standard solenoid valve is not working. Mainly due to fragments of dirt getting into them and holding them open. I need something that is positive opening / closing.
I am looking at motorized ball valves from Dealat, but they require as long as 16 seconds to open / close. No good...
Is there another choice for a positive acting valve that can work a bit quicker. Say 5 seconds max ?
3/4" valve flowing water to cool a cutting blade...
If there is supply of compressed air I recommend a pneumatic operated butterfly valve, works very well with dirty liquids, but maybe the minimum size is larger than 3/4 ".
Something like this
May I suggest creating a sediment tank to allow trash to settle,
then have a secondary filtration system.
no valve likes dirt.
I have used numatics for years. they are spool type valves and can cut small items as they shift.
regards,
james
I use pneumatic actuated ball valves all the way down to 1/2", no issues at all, and they are well under 1 second to shift. Not cheap though, so if cost is an issue, it would be more inexpensive to put a dual filter/strainer in front of your solenoid valves, and just clean the strainer/change the element as necessary.
But if the particles are metallic I think that sooner or later all valve types will fail.
As others have said before the only reliable thing would be to install a decantation tank and filtering system.
All good answers, Thank you..
My suggestion that we simply need clean water didnt go over well. So I'm still digging. The one thing I pointed out is the fact that we are using a very cheap sol valve to begin with.
The cheapest and most reliable solution seems to be a proper filter for the incoming water..
IF you are going to filter I'd start with a strainer with a magnetic plug of the sort provided in hydraulic systems, then a coarse filter downstream.
Hi everybody, I just started using Mitsubishi PLC and it is a completely new experience, nothing similar to what I am use to (AB), last week I...
4,535
Greetings, I have a machine with a SLC500 controlling a SEW Eurodrive Movitrac 31C VFD. There is a second 31C as a slave off of the master...
2,141
Hi All, Could you please let me know if any AB or any other PLC which operates with Battery and no external power supply? Thanks,
2,134
I am a newbie studying VFD. Can someone tell me what "MOP: Motor operated potentiometer is and how it is used? I did my share of looking up...
3,711
Hello All, I just finished programming some solenoid valves. I have to now program some Motor Operated Valves. The Controllogix PLC has 2 120VAC...
5,564
