Electrically gearing VFD's
wevie0037@
Jan 2007
Iowa
Greetings,
I have a machine with a SLC500 controlling a SEW Eurodrive Movitrac 31C VFD. There is a second 31C as a slave off of the master.
1.) The master sends an ENCODER signal to the slave
2.) The slave is geared to the ENCODER input from the master and watches its own encoder feedback.
3.) The slave is required to "home"
4.) The operator can bump the slave forward or backward in relation to the master during running.
5.) The motor is a simple 1hp induction motor with an encoder added on.
The slave drive malfunctioned and is no longer operational. There are none available and I'm told this model is discontinued. I would VERY much like to replace it with an AB unit.
I have a Powerflex70 with an encoder feedback card, but this doesn't help in following an encoder signal.
In my opinion, the PF70 is NOT the device I need here. I feel we need a servo motor and a motion drive such as an Ultra.
Signals to the slave:
Stop/Start from PLC
Encoder signal from master
Phase adjust forward and reverse from PLC
Signals from the slave:
Running/fault to PLC
Out of sync fault to PLC
Do you see any way to do this with a Powerflex? Keep in mind that the slave must accurately follow the master in order for the process to operate properly.
I have an application where a standard solenoid valve is not working. Mainly due to fragments of dirt getting into them and holding them open. I...
2,821
Hi everybody, I just started using Mitsubishi PLC and it is a completely new experience, nothing similar to what I am use to (AB), last week I...
4,530
Has anyone done any electronic gearing using a Nidec 750 series drive? I'm looking at a couple of configurations, but unsure which to go.
765
1756-L82ES controller, V33 lastest firmware using a Sick brand encoder to monitor position on the shaft of a conveyor. (call this conveyor) I...
1,198
I have set up a 755 with dual encoder board to follow a filler drive motor position on a bottle filler and capper machine. The master encoder is...
1,205
