Electrostatic Discharge damage photo
unsaint33
Sep 2019
MInnesota
118
The following is a set of photos illustrating ESD damage to a circuit board. I got this from here..
https://www.rs-online.com/designspark/what-is-esd-and-what-damages-can-it-cause
The picture I am attaching is from the webpage.
In the picture, the first two photos have a small arrow pointing to where the damage occurred. On the last photo, I have no idea what the damage is.
Can you please tell me what/how the damage is? And can I see that in the 3rd photo?
The 5Kx image is rotated about.. 190 degrees from the 400x image and zoomed in. take a look where that orange arrow is and check the similar spot in the blue. You should see the damage.
can you tell me what the damage is, please? I am a novice in electronics. Thank you for your reply.
Not sure if anyone works in this field or deals with these machines. Very high voltage (low amperes - 100mA or so). We are building a prototype...
1,363
I have been asked to convert the PLC on an electrostatic precipitator to something more current. I have everything I need to do the program...
2,343
Any one know iso 1438 open channel Rectangular notch discharge equation
1,578
Hi all, I have 4 indications for a discharge check valve, are, 1-fully opened indication 2-fully closed indication 3-open control 4-close control...
3,269
I ran into some trouble with an 842E Encoder, and what appears to be a problem with static charge building up from a product line and then...
5,050
