EMC and AS-i bus help
kas_
Guest
K
Hi all. Tried to search on the forum but no luck.
In my plant we got some problem with one of our gateways trips very often.
And I now think it`s a problem with EMC Interference.
But I do not know how to measure noise on the AS-i cable and what values I should be measuring. Should I e.g measure Hz and what is the normal values?
BTW I think I have ruled out most of the other possibilities.
Masters, Slaves, cables and power.
Sow I would just know a way to confirm the EMC interference with some type of measurement.
Thanks In advance :)
Kind regards
Kas
I am deciding on components for a bayed modular enclosure containing multiple VFDs (480V/350A/321Hp each) for a dynamometer. I am concerned given...
1,717
Hello, I have a basic question. I am looking to order a PF525, and noticed they have an EMC filter option. What is the purpose for adding this...
2,966
Hi there, Are there any experts or people with knowledge in the EMC and LVD testing here? if so, read on.. I have a display which is powered by...
3,915
To make a long story short: I have two identical drives which have the same problem. The amp is a SEW Movidrive MDX61B-0014 (which by the way is a...
1,572
Just wondering if anyone has any experience with this issue As part of a large installation we have a machine with 4 x 120HP 3PH motors each...
10,091
