Emergency Stop Circuit Scenario
There are several safety PLCs that support safety communications links.
Beckhoff has TwinSafe that runs over EtherCat.
AB, simens, etc all have theres. I have not heard of any safety over Modbus safety controllers though.
I am in no way an expert or even a novice on this subject, but I believe that the one thing that all "safety comms" have in common is that they are built on deterministic protocols.
The RS485 spec is pretty old and the com speed is very slow compared to modern communications, so I wouldn't really want to use it for safety.
You can do safety over Profibus (which uses RS485) with no problem. Oftentimes safety systems only communicate every 50 or 100ms. It's less about the speed of the network, and more about the devices guaranteeing safe behavior even if the communication stops.
g.mccormick is right; it's all about the determinism.
I would think that modbus rtu over 485 could be more deterministic than tcp due to potential queuing in switches etc.
I'm working on a project that has e-stop pull cords around the full length of a conveyor system which is about 750 feet long and it has 16 e-stop...
8,016
Hello everyone. This is my first time designing a system from scratch. The system is for a rubber injection molding press. I have the PLC all put...
35
11,602
Hi, My company uses Schmersal SRB-C.46 relays in an emergency stop circuit. The relay has 3 NO outputs and 1 NC output for monitoring. When the...
4,091
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
311
Hello, I have plc Schneider TM241CE40T with the hmi HMIS5T. Do you have idea how to disable a button after an emergency stop to vijeo designer ...
1,468
