Encoder Configuration with S7-300
eams2010
May 2009
Alex
26
I'm trying to configure an encoder with S7-300 PLC.
The module I have is SM 338 POS-INPUT, and I have an incremental encoder with resolution 4096.
I can not configure it as I do not know the no. of bits, the type of code (Gray or binary), the clock rate and the monoflop time as nothing of them is mentioned in the data sheet
the Encoder type is hohner H8A49A/AO/4096. (below the data sheet)
Technical DataConnection OptionsOperating temp:- 20 ...+ 60 degrees CCable12 pin- 4 ...+ 140 degrees FPS GNDBlack1On request:- 40 degreesPS 5 ... 24 VRed2Max frequency:150 kHzOutput AWhite3Current consumption:90 mA (max.)Output BBlue4Power supply:5 - 24VOutput OYellow5Weight: 21 oz (0.6 kg)Output A invGreen6Protection:IP 65Output B invViolet7Housing:AluminumOutput O invBrown8
Shaft:Stainless SteelBearings:2 x 6001 - (Z) (RS)Torque:0.7 oz/in (5 N-cm) Humidity:Up to 98% permissibleSpeed: 6000 RPM max.Shock:10g (6msec)Vibration:5g (500 Hz)Shaft load:Radial / Axial 10 NLine driver output max:50 mA per channelMax. ppr5000Inertia:100 gm-cm2
the referal to number of bits -gray or binary is specifically for an absolute encoder not an incremental one
the incremental has two inputs in quadrature and is normally used through a HSC or similar
I'm trying to configure an encoder with S7-300 PLC. The module I have is SM 338 POS-INPUT, and I have an incremental encoder with resolution 4096...
5,874
Hi all, I am using a B&R X20 unit and want to integrate an incremental encoder (OUT A, B, & Z). I have three BOOL digital input pins for my A,B...
480
I have Allen braidly plc 5/40 c; Lika encoder; HSCM Connected with Controlnet communication. How can I configure it.
1,202
Hi all, Before I ask my question, a list of hardware may assist in the search for a solution. Micrologix 1500 Base Unit: 1764-24BWA Ser B...
11,928
Hi... I'm working on A1SHCPU(Mitsubishi) and OMRON Rotary Encoder E6c3-AG5C (Gray Code Type/Resol...256). The purpose of this project is that...
7,119
