Encoder needed for k5300 drive
arvind_g
Sep 2021
Delhi
Hello guys,
am trying to figure out what specs an encoder should have to correctly connect it to the auxiliary feedback on an AB Kinetix 5300 servo drive.
I intend to assign it as a master axis and cam to it the physical servo axis as a slave. I know the mechanical aspects,PPR etc that I need.Also I am sure that it needs to be an incremental encoder.
Main question is that while the manual says 'The Kinetix 5300 drives accept motor feedback of various types on the MFB feedback connector and auxiliary feedback signals from TTL incremental encoders on the digital inputs and auxiliary feedback connector.', can I use an HTL encoder with 5VDC output?
Using a CIP encoder is NOT an option because of the price.
Any help is highly appreciated in advance.
Thanks,
Arvind
Do I need an encoder (slave) axis for my project? I am using a Powerflex755 and Incremental Rotary Encoder (scaled into linear movement axis)...
2,697
Hi Guys, Been years since I have done this stuff. I am struggling with the tracking/encoder and marrying the camera result data to the encoder...
19
8,016
Hi I have Micrologix 1100 and an incremental encoder, what I would like to do is convert the HSC:acc value to inches using a SCP instruction I am...
1,514
Help needed, Is there anyone who ever write code for OMRON Rotary Encoder with MicroChip's PIC16Fxxx series. I'm seriously needed. Thompson Soe...
3,460
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
251
