irondesk40
have a question. I have about 18 machines that involve feeding fabric, glue, etc. and there is a infeed table that I will build that will have a nip roller to feed fabric into what I will refer to as the master machine. The infeed table I have been told will always run a little faster than the master to develop a accumulation of slack material. The master machine I have not seen yet so do not know what type of controls are in it. The only thing I know is that the manufacturer may not be able to supply me a analog sensor to represent the actual speed it is running. I can mount a encoder on a roller that will turn as the fabric feeds across and connect it to a allen Bradley micrologix plc and detect the speed it is running and then use a analog output to a emerson drive that I will be using to control the nip motors. When you multiply this by 18 its a pretty good amount of money. Is there a device such as a redlion, or omega or something that the output of the encoder could be connected to and then give a analog output such as 4-20ma to represent the masters 0-10 YPM it may be running? I have looked at some redlion counters etc. and wondering if anyone has used something like what I have described to detect the speed of rollers, etc. and give a analog output. Just think it would be simpler than possibly using a plc and more cost effective.
