Specifying Settings for Connection Numbering For EPLAN P8
Settings for connection numbering are saved in schemes. This way you can access previously specified settings at any time and even change them, if necessary.
Project data > Connections > Numbering > Settings
1. In the Settings: Connection numbering dialog, select a scheme from the drop-down list.
2. In the Filter tab select the check box for the trade and connection Notes: type you want to number.
3. In the Placement tab select where and how often you want to place
the connection definition points on the connections.
4. In the Designation tab, define the format groups that are to be formatted together.
5. In the Display tab specify formatting for connection designations generated on the connection definition point. Among these formatting options are, for example, horizontal and vertical increments of the connection designation from the connection line, as well as text color, size, etc.
6. Click [OK].
The scheme is now set up and will be used when you are numbering connections.
Hope this helps!!!
