erasing memory slc 5/01
bakerboy_99ca
Mar 2004
London Ontario
58
hi guys,
i need to erase the memory from a slc 5/01, without removing the battery and waiting a couple of days.
It has a medar password protected program on it and will not allow me to overwite it.
I have done this before but when i searched for my original question posted here last year all the answers were deleted.
I remember something about entering memclr but in numeric form (like on a telephone) when promted for the password.
Anybody have any insight?...
Project needs to be done today so i will check back often.
thanks,
Mark
just found original answer and i thought i would share the answer i was looking for with all of you
The following procedure can be used to restore defaults to a Micrologix or SLC-500 processor
when the software requests a password. RSLOGIX 500 v3.01.09.02 or greater must be
used. APS and AI 500 software do not support this procedure.
NOTE: By following this procedure the program in the
Processor will be erased.
1) When prompted for the password enter MLCLRMEM , using the keypad of a
telephone you must translate this into its numeric equivalent of " 65257636 "
2) You will be prompted to confirm the clearing of the processor ladder logic program.
3) Once this is confirmed the processor will return to a default
( Out of the Box ) state with it's default program.
The software will then return offline to it's default screen.
B
hi, i am reusing a slc 5/01 from a medar control panel. medar has put a master password on the slc 5/01 so i cannot go online or download...
15,821
c5_98
C
We've gone round and round on this and just changed the two culprit processors. But in case that isn't the answer, I thought I'd get some ideas...
2,290
Dear all, IN S7200 for timers i am referring the preset values through word like VW500,VW504 etc. In case the memory of PLC is...
1,644
hello all, im working with an allen bradley 1769 series plc on an indexing table, I take a picture with a camera and determine whether parts are...
2,063
I want to clear out a chunk of data. Will this code work and is there an easier way? I have to do this 8 times for different areas (each with a...
1,628
