Error help on Logix 5000
Willlly
Feb 2018
Florida
I'm having problems with some uploads on logix 5000. Could this be a revision error or what? If anyone could help out that would be great! Thanks in advance!
Studio5K V21.xx.yy is 'Minor Sensitive' to the CPU Rev.21.xx.yy firmware.
The 21 software version needs to exactly match both the Major and the Minor of the CPU Rev 21 firmware.
One warning too:
You cannot have two different 'Minors' of the same Studio5K 'Major' installed and running on the same machine.
I've never seen that type of crash related to the revision compatibility, though you should pay attention to it.
More often than not, this is a permission problem. Try setting LogixDesigner.exe to run as administrator. You can also try setting User Account Control setting to a minimum. After UAC is changed, log out and log back in.
fatal error in rslogix 5000 v20 Error 0x80042082 RxE_locale_changed_by_outside- the locale language Settings for RSLogix 5000 was changed
2,008
I am new to compactlogix 1769 L30ERM PLC. when I was upgrading firmware to version 30 through control flash flowing error came. it is; and also...
3,032
I am getting an error : "Controller acknoledged the request of transition to remote mode but it has not completed the transition. You con't...
1,957
I was trying to open a file .RSS on RSlogix 3.0 and when i selected the file to open there's a message "error on file decompression and read!"...
4,688
Hello everyone , im using a IM153 as Decentral Peripherie, it uses profibus and it is a slave with the adress N° 2 everytime there is a problem...
629
