Error Stopping TwinCat Runtime
adcoPLC
Mar 2005
After a night of installing and removing programs and drivers. Changing settings everywhere. I finally re-installed my Laptop (WinXPprof). But the problem stays the same: everytime when I stop the TwinCat Runtime the system hangs.
After a call at Beckhoff they told me that this is a known problem with HP and Siemens Laptops. It must be a hardware problem but they have no solution.
Does anybody have an idea what it could be ?
Many thanks and kind regards.
Is is a total lockup or can you use CTRL+ALT+DEL to get into task manager?
If you can then i'd start by loking to see what the CPU usage is (i'd expect it to be 100% if there was a problem), if so then switch view to processes and see what is eating all the system resources, it could be that Twincat Runtime is utilising a memory area thats being used by another application, if that's the case, that proces will be eating up resources (probably) and you'll be able to see it. I've personally never had any major probs with Twincat but i'm not a great fan of it, I always found though that it runs best in Windows2000 opposed to XPpro.
It may be an issue with the chipset used on that particular laptop, I'm currently running it on a Packard Bell easynote and before that a Sony Vaio, incidentally, what brand and model is your laptop? it may be worth checking for updated drivers for your laptop's mainboard on the manufacturers website, it probably wont work but try running in compatability mode for Windows 2000 see if that makes a difference
We have several Powerflex 4M (22F-D013N114) VFD’s controlled by compactlogix PLC’s. Control is simple, a run and direction signal with the speed...
1,532
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
291
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
95
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
178
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
143
