ESA HMI and Siemens S7-300 question
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7 manager. The HMI is connected with the device below. My question is, am I able to connect to the HMI for an upload using the same DB9 port that I did to upload the PLC or do I need to connect a separate cable to the HMI? I am told I need Polymath HMI software for this and I would like to confirm this with someone who is savvy with ESA's. The model is VT50500000 with rev 2.3, date 29/10/2010. The touchscreen works fine but the display has lines all through it and only experienced operators that have memorized where the buttons are can use this thing. The customer already purchased an Automation Direct HMI before I arrived on the scene and would like me to change it to their new HMI. Although I have the PLC project, I have no descriptions or anything, which is why I would really like to upload what is in this HMI. Thank you
So I was playing with this yesterday and NOW, I see the program running in this CPU in my TIA V.18, which I couldn't before. The only difference is, I created the chassis and modules first. I did notice this also. It appears as though this COULD be the HMI, which has been the main problem all along. Does this mean I should be able to access the HMI from TIA portal?
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
88
Hiii, guys I need to take backup from esa vt series hmi like vt 310w n vt 170w . Plz tell me how to get it. Also I have vt 5.17 version and...
1,825
Hi experts, We have one control logix plc with ethernet module which is already running for a long time. now we wish to take some data on a...
2,497
I need to get uploads from a Moeller PS4-141-MM1 PLC and also from an ESA VT505W HMI on the same machine. It looks like I need Sucosoft S40...
1,639
Hi, Does anyone know the pinouts of a programming cable between PC (RS232) and HMI Esa VT190W (MSP)? I have seen a similar post but it was for...
2,217
