Ethernet connection with Siemens S7-312C and CP343-1 Lean
edda
Jun 2008
At the office
100
Hi!
I have a question regarding ethernet communication with a Siemens S7-312C and 343-1 Lean.
For some time I´ve been using the S7NetPlus library (https://github.com/killnine/s7netplus, in 10-15 diffrent projects) with different types of CPUs, Ethernet cards and so on and it works great.
But now when I try it against a 312C and 343-1 Lean (Both version 2.2 and 3.0) I can't get it to connect correctly. Is there something special with a compact cpu? If I try with Beijer iX (the HMI software we are using) the CPU response correctly.
(also post a this as an issue in github).
Best Regards
Edmund
You must look at the CP343-1 Lean Vs CP343-1 specifications. The lean CP, doesn't have an ISO communication. I think this is your problem.
Thanks for your reply nonuke!
But the problem is if I replace the CPU (leta say a 315-2DP) the Communication works great?! Still the same CP card.
BR Edmund
What type no of the 312C ? What firmware version ?
Can you use the CP343-1 LEAN for going online with the 312C with Simatic Manager ?
Hej Jesper,
The Number is 312-5BD00-0AB0. I dont have any info about FW version here. Yes i can go online with the manager via the CP card and Beijers iX software works as well...?!
I would update to the latest firmware (if it isn't already)
Sure I will tell the custumer to upgrade the FW to the latest (if not already).
But I just want to confirm that there should not be an issue with the compact CPU. Beijer is using ISOonTCP and that works great on the Lean card.
Hello, I have connected ethernet cable with my laptop and the s120 control unit. setup my laptop ip 169.254.11.1 and subnet mast 255.255.0.0 ...
20
5,564
So I have finally had to bite the bullet and do some modifications to some Siemens PLC code written in TIA. I have got both V10.5 and V11...
4,759
I searched the siemens help site but couldn't find what I need. I am using a 319CPU PN/DP. I am reading data from a scale using the standard...
2,208
We have siemens s7 300 PLC which is connected with Hitachi PLC through ethernet with CP343-1. When we connect another computer in that network, we...
7,159
Can some-one please help me. I have a Siemens 317 2DP\PN CPU on a packaging line. I would like to know that is the most effiecient way to get a...
1,440
