exaopc server connection
atomtm
Jun 2014
Germany
130
Hello everyone!
I am trying to connect to an EXAopc server from yokogawa. The Opc client can list the DA servers but once connected I get callback errors.
The server is using EXA as user. Is there a default password I can use for this?
Thank you in advance
Hello. If I understand correctly EXAopc is OPC "Classic". If the OPC client and the OPC server are running in different PCs you need to do a number of DCOM settigns. Are the EXAopc server and the OPC client running on the same PC or in different PCs?
They run on different machines and communicate through the network.
Well I got some progress today and can connect through Matrikon OPC explorer, but for some reason softing OPC (which is the required client by the way) is not possible to enumerate the remote opc instances. If I connect with the a username that is present also on the.server I can enumerate the opc instances on the remote server but can t get realtime values.
OPC expert also works correctly. So anything but softing software which I think is something related to dcom permissions ...
Hello again. The attachment is an old Softing technote for DCOM settings. In my experience, whoever has a look at this document solves all DCOM problems. I recommend you give it a quick look. It might be helpful.
When i load my client a[plication the following error is recorded in factorytalk view studio log Failed to load data server...
48
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
94
hi everyone, i have problem regarding Audit in FTV ver 12,In audit message "service disruption:<HMI server name>:<SERVICE NAME>" message logged,i...
64
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
79
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
299
