excitation
What a great link! Have not played with these things since I was an apprentice - a decade or five ago.
Generally, synchronous motors are used for synchronous speed and to improve power factor. I have never really heard of a "synchronous" generator. All generators are driven at synchronous speed by the engine.
Is this a "trick" student question?
Bob, the term synchronous generator is probably a misnomer. It is used here in the US, and seemingly other places, to describe the use of a 3 phase induction motor as a generator driven by some prime mover. The practice is often used for peak shaving but the characteristics of the induction motor do not make it capacitive as I understand it. DickDV will doubtless have more precise info on this subject.
Doing a little research on the subject of leading power factor and motors, I find that you can use a synchronous motor in that fashion by over-excitation of the rotor. This may be what the original question was really about.
/nod. I got heavily into large synchronous motors at one site that had a 2500HP one, virtually never used, and the electrical supervisor heard about using them to correct power factor.
At the time, they were running a pretty bad lagging PF, and were considering an expensive switched capacitor set. In the end, we brought it to near unity with just the motor.
I have a Allen Bradly Signal Conditioner card (931S-B1C6D-DC) hooked up to a strain gauge. The excitation voltage is 10V, the output is 4-20 ma...
2,053
Hey Guys, I'm looking for a precision 10v or 12v power supply for load cell excitation. It can be either a 120/220VAC input / 10VDC out power...
4,423
Dear Friend I realy needs your help , I have Alstom DC excitation system with VNTC/WNTC+MD29 drive ,we codnt working with Automatic PF correction...
1,616
Is there any kind of system function or something that stops cyclic interrupt during excitation of some other function. So for example inside fc3...
2,012
What excitation voltages are normally used for resolvers?
1,248
