Exercise #3 Traffic light with delayed green
Anthonywade
Mar 2009
Addison
I am having problem is here what i has .I need 1 second period when both direction will have their red light illuminated threr sre actually 2 such 0verlaps that need to be acconted for
Red=O:02/00, Green=O:2/02, yellow=O:2/01
Green=O:2/06, Amber=O/05, Red=O:2/04
Green 8
Amber 4
1s
8 sec
4 sec
1s red
Exercise #3 - Traffic light with delayed green
Anthony;
I would be glad to help you out, the code does not sound that complicated. I am confused though as to what exactly you need the logic to do.
By the title of the message, it looks like this is an exercise for a class in ladder logic. Perhaps you could type the question exactly as it appears in the assignment.(y)
Tango,
It is the old traffic light program. It has been solved, discusssed, debated, and condemmed on this site for years and years. Surely with a little searching, AnthonyWade can find what he needs.
I will give him some little hints anyway.
1. You can use 6 timers (1 will do), but remember it is a cycle, it should continue to loop. You never want your lights to stop working. When your timer T4:5 finishes, that is the end of cycle and T4:0 should be reset and start the cycle again at 0 seconds. The easiest way is to put a T4:5/DN XIO on Rung 0
2. Go back and do what you should have done first, that is to make a timing diagram showing what time each color light goes on, and what time it goes off.
3. Now look to see if some lights can be defined as combinations of other lights. For example, the red lights should be controlled by just two different timer DN (Done) bits (in series for one red light, in parallel for the other one), while all the others can be controlled by a different single TT (Timer Timing) bit.
4. You are shooting for a 26-second cycle, so set your timers for 80, 40, 20, 80, 40, 20. That gives a 28 second cycle, but the extra 1 second for each Delayed Green results in no crashes.
Exercise #3 traffic light with delayed green
Anthony;
This is from exercise 1 and 2 traffic light, than my instructer want me to modify this one.
Modify your program so that there is a 1 second period when both diresctions will have their red light illuminated. Note that threr are actually 2 such overlaps that need to be accounted for.The timing diagram belows the six discrete timing intervals required to accomplish wiyh desired sequence of operation, and wiyh proper cascading you should be able to come up with an easy to follow solution using just 6 timer.
Green 8
Amber 4
1s
8 sec
4 sec
1s red
6 timers?
Anthony - you can do this with a single timer that resets and cycles continuiously, and then just use compairson instructions to turn on your lights at cirtain time periods within that cycle - i remember that assignment from my student days, except in our case we had to design the program using as few rungs of logix as possible and only a single timer
Search for "traffic light" right here on PLCs.net. The Delayed Green is no problem with 6 timers.
Hi.. I've just completed Exercise 2 of Traffic Light simulation (using WordCompare). The one about Walk sign showing and blinking. Please...
3,075
Hello, I am trying to resolve traffic simulation exercise 1 where we have: For simplicity, I eliminated amber color for now. I made a ladder...
1,542
Hey there, I have been doing all these exercises until this one where you have to control the pedestrians aswell. So my question here is, how do...
3,435
I need help with Advanced Batch Exercise :D:D:D:D:D please
2,437
Hello. I am having troubles with Batch Mixer Exercise 3. I need help with which PLC controls I need for the following steps. In Silo Lab Exercise...
2,471
