Experience with using Codesys
Adenitz
Feb 2010
tir
41
Hi to all,
does anyone have experience with using Codesys software for PLC programming?
(https://www.codesys.us/)
What I can find out is that this software is manufacturer independent software for PLC programming that is made according to the IEC61131-3 standards.
So, this means it can be capable to be a programming tool for both Siemens PLC as well as for Allen Bradley.
I wonder if anyone has used it before and would like to learn about their experience?
Thank you!
Nope, will NOT do either Siemens or Allen Bradley.
It will do Wago, Beckhoff, Lenze and anything else that can be programmed with CoDeSys.
You'll need to install "targets" from each manufacturer if you buy the generic CoDeSys package.
'manufacturer independent' does not mean 'supported by all manufacturers'. It just means that it's not owned by one manufacturer (who then restricts its use to their own hardware).
AB and Siemens prefer to lock you into using their software, so they don't make hardware that will run Codesys. If you want to use Codesys in a PLC, you need to buy a PLC that supports it.
Thank you guys,
it sounded too good to be true anyway.
Do you have experience using this software?
Here is my recent experience using the Zebra AOI for printing from the PLC. Please do not ask me for my PLC or template files as they are the...
12,322
I am developing a new production line for energy recovery units and the controllers from delta electronics were suggested by a vendor. The price...
1,837
Does anyone have any experience using the prosoft MVI69-Mnet (Modbus TCP module) with a Compactlogix? I need to use it to communicat with another...
4,071
@ All: what is your best guess on a potential range in increase in efficiency in % (i.e. saved programming hours, greater output, etc.) when...
351
Hey guys, has anyone worked with any type of Keyence PLC and could share their experience with it? Vendor showed me camera footage reply of a work...
1,179
