Export import screens in ftv me
roxusa
Nov 2008
NJ
994
Is it possible to copy individual screens from one project to another
in Factory Talk View Machine Edition. I have FTV ME 8.1 and would like to add the same screen to several projects, I realize I would have to change the connection tag to match the shortcut for each project but the rest would be the same. Thanks
Yup- right click at the top of the list of displays, and select "export displays". Select whichever ones you want. Make sure the displays are closed first as that can cause errors.
On the project you want to import them to, do the same thing and select "import". You may have to make a new blank display for each one. Just fiddle with it, it's pretty easy to figure out the quirks.
...You may have to make a new blank display for each one. Just fiddle with it, it's pretty easy to figure out the quirks.
If you use the batch import file instead of individually importing them, you don't have to do this - FTView will create each display in the batch automatically.
Drag and drop is still easier, if it's an option.
Didn't realize that you could drag and drop from different applications! Good to know!
I didn't for a while either. A coworker of mine said one day "why don't you just drag/drop those?". WHAT!?, I've been doing this the hard way the entire time!
How to do wondare intouch Screens import & Export,how to make windows viewer
973
Hi, first time poster. I am a new graduate working in the automation and controls industry for an OEM. I am working on making a new HMI interface...
18,358
Hi, Import and export of project text is no problem. But how does it work if additional texts are added after I send a exported copy of the text...
878
Hello, I'm digging all over the internet to find a solution for this but haven't come up with anything yet. We have 3 nearly identical machines...
965
Hi all, Is there a way to import POU's from ABB Automation Builder to Schneider EcoStruxure Machine Expert? They both run Codesys software. ABB...
1,895
