Extract data to SQL in "real time"
gergallardos
May 2014
Mexicali
I have a SLC 500 and connected to it via DH+ is a PanelView Plus. The PV+ has an ethernet port
I'm looking for a way to get the status of some bits in the PLC and register them in a database as well as use them to display "real time" alerts in screens located in our production line. By "real time" I'm not meaning milliseconds, I think anything around 2 secs should do the trick.
According to Allen Bradley the PV+ can't pull these values and store them in a database, apparently it is restricted to datalogs.
I have been looking at the OPC Servers like Matrikon and Kepware. Actually Matrikon has an ODBC client for OPC Server, could this work?
Any other suggestions?
Have you gotten a price on factory talk historian? I use it and it is a pretty easy software to work with. For just Excel files, the processor can probably achieve a datalog alone.
Hi Passman,
I'm checking Webdock DataPort's webpage and seems like what I need. I also took a look at Ignition by Inductive Automation.
Do you know if they could reach the PLC through the PV+ ethernet port or do I have to get an ethernet module for it?
Hello,
If you are planning on using a PC running a MS Windows OS, PeakHMI might be a good solution for you.
Hello,
Hello Mark,
I guess that once connected to our network using either an ENI module or the PV+ ethernet port, I would opt by running the applications in our server.
Can this PeakHMI software pull values from the PLC through the PV+?
>through the PV+?
I am not sure what communication options the PV+ offers. If it offers the data as an OPC data server, PeakHMI has a built in OPC client.
Normally, PeakHMI communicates directly with the PLC. Depending on the PLC you might be able to connect directly to it from PeakHMI.
>through the PV+?
It's a SLC 500. So if I put an ethernet module I would be able to access the data with PeakHMI and then upload it to a database?
Hello,
>It's a SLC 500.
OK, so it is one of the brick ones, not a 5/03, 5/04 or 5/05
http://ab.rockwellautomation.com/Programmable-Controllers/SLC-500-Controllers
Right. Using the included ODBC driver you can save data to any database that supports ODBC. I have never seen a database that does not support ODBC. You could even use Excel or Access.
On our website we have an example project logging to Excel. I have a test project logging to MySQL. An example logging to MS Access is around here somewhere. Creating a new example project would be easy.
We also have an example project logging to a text file.
I would like to extract data from a Bizerba is50 using WebSockets or Profinet. I currently cannot find any information on the subject, any help...
731
Hi all - got an S7 classic Step 7 program. I have a variable that's a TIME data type it contains a value such as T#1h30m5s - how can I extract...
2,572
Hello guys, I have made a data collector which counts how long was light on. I made it by counter which counts minutes when it is on, then...
1,330
We are doing a proof of concept to try the following 1) get data from KepServer 2) The Data will be transformed eg: a Status code of 1 gets...
1,217
Hi I am planning to remotely extract data using the data extract utility. THE ML 1100 will have a static IP and I would like to know if I can...
2,659
