Extract transform Store data
MKM@mkm
Aug 2016
NA
We are doing a proof of concept to try the following
1) get data from KepServer
2) The Data will be transformed eg: a Status code of 1 gets transformed to "No-OP"
3) The transformed data will be moved to a database of Message Queue
Noe: The reverse operation can also happen where in data moves from MQ\ Database to Kepware
We are planning to develop an application which pings the kepware tags and move them to database or MQ based on configuration after transformation.
The data that PLC program creates will have 2 sections 1) header 2) Information
Header will have info like source and destination and other fields to maintain data integrity. Information will contain the actual data to be written to a database table. The information string will be separated by special characters will be going to a single table having multiple columns
Eg:
If info string is 1|051120160326|No-OP|25 this will go to a weight table having columns ID, Timestamp,Status,Total Weight.
Is this a valid approach?
A better question will be, are there applications which provides the same kind of service?
I am looking for how this is currently done by the industry and if we are in the right path.
We would love to avoid writing a new application for this, if there are off the shelf solutions available.
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
129
Hi everyone. Quick questions. On UnityPro, I want to open and quickly read tags from a .STA files witouth opening the program. I have 30 plc...
152
Hi all, I am working with an IO link sensor (measuring current across motor)and need to read in and store the sensor values for 5 seconds, then...
1,221
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
565
Hi guys, I need a GSD file for the following sinamics drive (S120). IO Device SINAMICS S120 CU320-2 PN V4.4 PN-V2.2 with DriveES/SIMOTION...
1,448
