EZ Mini PLC/HMI
DoubleJ
Oct 2017
midwest
Anyone used an EZ Automation plc/hmi? I'd like to utilize the RTC and need assistance on how to use it in the ladder logic.
https://assets.omega.com/manuals/M_EZPLC_SOFT.pdf
In the above manual Chapter 3 - Programming EZPLC will show you the system registers. SR10 to SR20 will contain the information about the RTC.
You mentioned in the title of the post the Mini version.
https://www.ezautomation.net/HMI-PLC-All-in-One/EZTouchminiPLC/pdfs/EZTouchMiniPLC%20Manual.pdf
The manual does not document the same registers as mentioned above.
I would contact the manufacturer to see if this is possible.
I hope this helps you out.
Regards,
Mini PLC Specifications: 12 Digital Input 7 Relay Digital Output 8 Analog Input 1 RS232 to USB Port Mini PLC Contents: Control board + USB cable...
2,492
I have been tasked with a job to count the number of people in a site basement and display this information to the sites control room. Currently...
2,687
1772-LXP Mini PLC/2. Power supply is built into the CPU module. Can this be powered up without a chassis to preload a program? Has anyone...
1,393
I have a home automation project and am trying to pick a mini (low budget) PLC. What I need: 3 analog inputs and 1 digital input 1 analog output 2...
23
7,340
I have a really old machine that was donated to my company. The PLC is one of the oldest ones I have ever seen. It is a "mini"<-yeah right, 2/15...
3,393
