Mini 2/15 PLC lost its program
Skiroy
Mar 2012
Panama City,fl
199
I have a really old machine that was donated to my company.
The PLC is one of the oldest ones I have ever seen. It is a "mini"<-yeah right, 2/15 and came with a cassette tape with the program backed up one it,which undoubtably is useless.
But my question is,do you know if these things have memory or EEPROMS in them that would store the program in it like a SLC 500?If the battery dies and it sits without power is the program gone from these dinosaurs?
And do you know the module needed to attempt to put the program back on it with the cassette tape and any operator instructions?
Yes, an EEPROM chip was an option for the PLC-2/15 controller.
http://literature.rockwellautomation.com/idc/groups/literature/documents/td/1770-td008_-en-p.pdf
My recollection is that there was a 1770-SA tape drive, that was an audio-style cassette. The later 1770-SB used a data style cassette.
These are as obsolete and rare as the PLC-2 controllers themselves. After using mine only once in 13 years, management made me get rid of it.
You could try to find or rent one of those tape drives, but it might be just as effective to reverse-engineer the control program from scratch.
In my just in case one day storage of junk
I have a cassette recorder
a T2 terminal that was used for programming
the cables needed
hopefully the manual
and to show my age the knowledge to use them
If you cant find anything locally for you make contact
and we could try to work through a resolution
I do agree with Ken though that a new program from scratch would be best.
Hi I can remember using a laptop as a 'tape unit' for a T3 terminal with software from Taylor. Not much use to your situation but just for info
Funny Gil47,
I had a large cardboard box labeled "Mick's to be used some day box".
I never threw things away.
How did the data style cassette look? Mine looks like an audio style but did they look different?
Where would I look for the EEPROM?
Have a look at the first PDF I linked to; there are photographs of the EEPROM installation. These were actual chips with pins; they weren't a socket or a cartridge.
I believe that the 1770-SA was the audio-style tape drive. In theory you could play back your cassette and find some way to extract the digital signal, then decompile it through one of the old software packages.
In practice, throw the controller into a deep scrap bin as hard as you can.
the cables needed
Thats really thoughtfull thank you.
To be honest with you guys I went to school for automation about 4 years back. I pursued engineering school,dropped out and got a music production degree. I just within the last year have been in the industrial maintenance field and just in the last couple of months have I been trying to get back up to speed on the wiring and programming side of things I was once decent at,but it was with RS LOGIX.
The point is that it has been awhile since I programmed a PLC and I dont know anything about the software or program differences with this kind of obsolete PLC. Though if it is gone there is not much for me to mess up its just convincing my boss of a small company to buy the software and putting myself in a position where I am saying I can reprogram may not be wise for me just yet. If I can get this tape machine cheap and restore the program I will be golden. Then when the pressure is off I will convince them to buy the software so it doesnt happen again. Then I can experiment with it and learn it.
So what would it take to get my hands on this machine to try out? I dont even know if the cassette is good anymore. It was sitting in the machine for what looked like a decade under a accessory 120V outlet.
Your the man. I just verified that there is no EEPROM in the slot and according to the your link the EEPROM is either faulty or uninstalled if the memory LED stays lit,which mine does. The batteries read 1.47V is that close enough to 1.5V to be good? There were corroded though and the Low Battery light was flashing.
So without power,batteries or a EEPROm how long will the program remain in this unit's memory?
That's bad news if the Low Battery light was flashing. I don't think these controllers had any memory-support capacitors; the RAM was cleared instantly if the power went out and the battery was low or missing.
This is one of the reasons the late-1980's SLC-500 controllers got RAM support capacitors. You can pull the battery out of an SLC-5/03 for a month and the program will probably still be there.
My recommendation is to see if your local Rockwell Automation office or distributor has a PLC specialist who happens to have one of these tape drives.
If I remember correctly you could use the old Taylor software to read that data cassette. I 'm wagering that you had to use the 1770-SA though. I've actually got an original copy of Taylor software for PLC-2 on the top of my bookcase. I'm kind of short so I can't get it down from there :) If you need the SA there's one on ebay right now for $175.
Good luck,
(8{)} :) .)
(Yosi)
Anyone used an EZ Automation plc/hmi? I'd like to utilize the RTC and need assistance on how to use it in the ladder logic.
1,264
Mini PLC Specifications: 12 Digital Input 7 Relay Digital Output 8 Analog Input 1 RS232 to USB Port Mini PLC Contents: Control board + USB cable...
2,496
I have been tasked with a job to count the number of people in a site basement and display this information to the sites control room. Currently...
2,687
1772-LXP Mini PLC/2. Power supply is built into the CPU module. Can this be powered up without a chassis to preload a program? Has anyone...
1,393
I have a home automation project and am trying to pick a mini (low budget) PLC. What I need: 3 analog inputs and 1 digital input 1 analog output 2...
23
7,348
