EZ TOUCH bmps out
Orn Jonsson
Apr 2002
Boise Idaho
125
Hi there,
I am putting together a user manual for a client of mine and would like to include in it some pictures of the MMI touch screens that are associated with the project. I am using Automation Direct's EZ TOUCH.
Any ideas on how to; export, copy or otherwise get an image of the screen from the programming software into a file i.e. bmp, jpeg etc. that I can then use in MS WORD or Pagemaker............
Thanks,
Orn
You probably already know this and are looking for an easier method, if so, please ignore, but just in case:
If you hit the Alt + printscreen button to copy the image to the clipboard, then you can hit Cntrl+V to copy the screen shot to paint shop pro. There you can crop the image, expand it, and add text and save the image as a .bmp to be imported into your OIT panel.
I agree with ganutenator's method as being the easiest, but you don't need a fancy editor like Paint Shop, Photoshop, etc... MS Paint works fine for simple stuff like this. Just select the portion you need and copy/paste.
As far as converting the bitmap to another format (jpg, gif, etc.), get yourself a copy of IfranView. In my opinion, this is the best damned image viewer/converter out there. And it's free!!
http://www.irfanview.com
I found this program a while back, and can't live without it now..
-Eric
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
186
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
134
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
143
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
130
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
325
