rpoet
All,
I know that AutomationDirect no longer sells the EZ-Touch line of HMIs, but I have a few questions concerning a surplus AutomationDirect EZ-S8C-F I picked up.
-I am planning on connecting the HMI to a DL-06 and three GS1 drives (and possibly more later) through RS485 (two-wire). I'd like to use a DB15-m to RJ11 adapter on the HMI and a HD15-m to RJ11 adapter on port 2 of the PLC to connect to the GS1's with the 10-port RJ11 distro block, part # ZL-CDM-RJ12X10. I'd like them all on one network so I can take advantage of the higher coms speed on port 2 of the PLC. Everything will be in one cabinet, and cable lengths will be short. Assuming I use MODBUS coms, does anyone see any problems with this setup? Can the HMI and the drives coexist on one network with the PLC?
-Where can I buy raw 6 cond. cable, similar to the cable used to build AD's RJ11 cables? It's a cinch to make my own RJ11 cables, but I'd like not to use the flat telephone-style cable, as it's hard to work with if crossover cables are needed.
I have need to display the degrees of rotation of a turntable. HMI will be receiving the value from an absolute encoder, and I'd like to use something line a circular analog graph, but I can't find a way to display a full circle. At this point, I'm thinking of drawing a static circle, and using visibility bits to display dots every 30 degrees around the circle, and display the exact degree reading in a box in the center of the circle. Not my favorite idea, but that's it so far. Any other ideas?
I double-posted this thread to AD's tech support site, in hopes of reaching a larger audience.
Thanks for the help,
rpoet
rpoet
