Factory talk activation RSLogix500, PanelBuilder
gbradley
Apr 2002
Corona, Ca.
1,637
My TechConnect is up next month so on the renewal I am considering changing my Master disk activation to Factory Talk activation.
When using Factory talk activation, is there a quick way to transfer activation from one machine to another?
Is the Factory Talk activation software easy to use?
Can I Uninstall the activation from my laptop and then Reinstall it onto my workstation? (I don’t ever plan on running them concurrently)
Is the USB dongle (9509-USBDONG) a better way to go?
I already have the 1747-UIC plugged into one of the USB ports, I would prefer to not to have to plug in another device.
Thanks for any advice.
In my humble opinion, it's a PITA. I rolled out a couple installs of RSView with the USB dongle and it went OK - I think they are just doing this because the old style activation was so easy to pirate.
Just stick to what you know, do the old installation with master disks.
With factory talk, you will have to release the license which is then entered into ABs database. It's web based if I remember correctly, and you can only release it twice in a 24hr period.
I like the USB dongle, it allows myself and my co-worker to both utilize RSView but not at the same time. Saves money on only needing 1 license, and it's as simple as installing the dongle into the USB port. Setup is pretty easy, you just specify the hardware ID of the dongle so RS will search for it upon startup of your selected program.
Good luck!
If you need to move the license frequently then the dongle may be your best choice. However, that is something you have to buy, and it is something that can be misplaced.
As an alternative, consider setting up your laptop as an activation server. Using Concurrent Activation your laptop can own the activation and use it when needed or it can be "checked-out" to your desktop as it is needed. It can then be returned to your laptop when done.
This method does not require any sort of "rehosting" or time constraints.
OG
OG
Yes that's the ticket.
Is this done using the Factory Talk Activation Software?
I don't recall the exact date, but the Master Disk Activation will be disappearing soon and you will have no choice but to use the Factory Talk activation.
Hi, I had a the safety editor license for Studio 5000, it has appeared to have vanished from my machine and in activation manager. I put in my...
1,641
hello all, Just a quick question about factory talk activation. Can the lic file be moved to copy activation. How do i back the activation if...
4,534
(I posted this on the Rockwell forum a week ago, it has 7 views and zero responses.) As of now, we have Factory Talk Activation running on an...
5,755
I am currently using a license server for several computers. I installed RSLogix5000 v. 20.04 onto a machine. When that machine is on, it...
1,915
I have an ex employee laptop which has rslogix 5000 software and it has the factory talk expired. When I try to look up the activation it does not...
9,297
