Factory talk historian SE - Matrikon OPC server
Dec 2016
Bogota DC
Can the FT Historian SE catch and store data from an OPC Server like Matrikon? If so, Would the FT Historian take the timestamps directly from the OPC tags or does it put the timestamps from the server where the FT Historian is installed?
Does the FT Historian SE license come with the Microsoft SQL server included?
Tks
Regards.
Tks
Regards.
Can the FT Historian SE catch and store data from an OPC Server like Matrikon? - Yes, You will use the FTLD interface to pull from the OPC server.
If so, Would the FT Historian take the timestamps directly from the OPC tags or does it put the timestamps from the server where the FT Historian is installed? This is a config setting, It can go either way.
Does the FT Historian SE license come with the Microsoft SQL server included? So, FT Historian comes w/ Sql Server Express to handle the AF database. The actual historical data is not stored in SQL however. I believe there are some SKUs that you can buy SQL Licenses with though, you'd want to talk to your acct rep for those.
Hello, Bit of background on the job I am carrying out. Old Setup: Data from CPU ----> Historian ME module -----> Historian SE V3.0 Windows...
1,237
We purchased the OLEDB provider for FHSE (PI) and PI OLEDB MMC snap-in does not work/connect and states the following message: [-10722] PINET...
2,905
I have a customer that upgraded their RSV32 to FTV SE, their reports no longer worked so they bought FT Historian and FT Historian add-in for...
5,079
Hi, Im busy trying install factory talk activation 3.62 to install and run transaction manager 10.10 on a Historian server SE 3.0.1 which also...
4,382
i have a rack mount server running Xen centre for virtual machines with 1 TB raid array. it has to act as HMI server with 3 clients, and historian...
3,260
