Factory Talk ME - Passing Parameter File to Macro?
kdcui
Dec 2007
USA
386
I'm wondering if it is possible to pass a parameter to a macro.
In this case, I've created some global objects and made them into a faceplace. When called upon by a Changescreen button, a parameter file is passed to the screen containing the objects, which use parameter placeholders.
Will macros work with these parameter placeholders if I use macro buttons on the faceplate screen?
Let's say one of my parameters is:
#1=[PLC]OUTPUT_ON
Where OUTPUT_ON might be a UDT.
So my data links on any objects with the placeholder are looking like:
Value <--> {#1.whatever}
Can I use the same format for a macro?
EX:
{#1.whatever} = Expression goes here
or
{Some tag} = {#1.whatever}
I've tried using both # and %, but it doesn't seem to be passing to the macros, so I didn't know if there was a special syntax I need to be using in order to make it work.
I've tried this also and discovered that, no, you can't pass tags to a macro. For each device, I had to create a separate parameter file and macro.
With RSView SE, you have a lot more flexibility and you can do what you are asking without a parameter file or a macro. You can create multi-line scripts within an "On Touch" animation.
Thanks. Yeah, after about an hour of searching the help and trying to tool around I managed to come across a line in the documentation that said placeholders can't be used in a macro.
I really wish we were using SE; I was browsing through some documentation for it and it seems a lot more flexible.
In any case, instead of using macros I ended up manipulating some things on the PLC side to accomplish the same task.
I have defined a global object, which when clicked on, opens a display. I have not been able to pass tag subtitutions to that display. The "Global...
9,657
147
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
73
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
79
Hi Friends; I have a red Explanation Mark on Factory Talk Directory in Task Bar. Before Update the windows and installation of AutoCad it works...
175
