Justshoot
I am using Factory Talk SE in local mode with a compact logix processor. I have a application with weigh scales, that when the scales are full and other criteria are met, I need to print the graphpic that holds the information. I have a tag configured in processor to trigger and created the event, in events but can't seem to get the printdisplay function to work based on the tag value.
Am I way off base or can't I do this? I also tried to just place the tag in the expression as you would with simple color or graphic.
Any help on this would be greatly appreciated I'm at wits end trying to get this to work.
