Factory Talk Restore Application
f16bmathis
Sep 2013
Wisconsin
131
I'm trying to restore a .MER file to a .APA file to edit in Factory Talk View Studio Release #6.00.00, Patch/Pack #00, Build #16. I started by going to Tools, Application Manager, Machine Edition, Restore Runtime Application,then selecting a .mer file I wanted to restore. When I click on OK, it says the file is not a valid runtime application file.
It worked on the laptop at work, just not my personal laptop. Is there a version problem?
Thanks!
a) Are you using the same FTView version (or newer) that it's installed in the laptop at work?
b) Are you using the same FT Platform version?
c) Did you installed RSLinx Enterprise on your computer?
d) Is the read only attribute of the .MER file set?
e) Do you know if the original project uses any ActiveX object?
Hi all, i'm trying to restore an application with Rockwell's "Distributed Application Manager". And send me this error message: The application...
1,546
Hi all, some one can help me with a restore on Rockwell Factory Talk Transaction Manager? FTTM V10.10, run at Win7 64, Solidcore installed and...
2,977
I need to make a few simple chnages to a factory Talk View SE application. It's Version 5.10. How can I backup and restore the application to my...
39,446
I have seen a little of this discussed but wanted to relate my specific problems. I am using Factory Talk View Studio Machine Edition running on...
6,884
145
