Factory Talk to PLC5 Tag Syntax
Uzzy
Feb 2012
Windsor, ON
Hello, I've looked around here and Allen-Bradley and I can't find exactly what I need. I'm converting an old 1400e to PanelView Plus and I'm a little unsure of something. We had everything working fine on RIO, but now we're forced to switch to Ethernet (wish we would have known from the start).
I already found out that Bit Array tags are not supported by Ethernet and I'm working through that issue, but another problem is Word Array. I had the issue with the alarms tag, but found an answer in the User Guide. Where {::[RIO]N177:600,32} worked just fine, I have to change it to {::[Ethernet]N177:600,L32} for Ethernet.
Basically, my question is, do I have to change all of the other multiple word tags to have the (,L#) or is (,#) going to work? I would just test it, but that's not possible right now as the line I'm working on is in full production mode and my conversion window is relatively small.
I just upgraded a few of my servers to version 10 the upgrade worked fine but for some reason all my short cuts that I linked to PLC 5's will not...
1,600
I am using factorytalk view studio 7. I am trying to pull data from a plc5/25, from N10:0 to N10:9 and display this data in ascii format. I am...
14,691
I am look to write RIO tags for a Panelview 1500, firm 5.0 to PLC5 5/60b processor. Hoping to find tag samples somewhere with no luck. I have...
4,142
I am updating a project used panelview 1000, it connected a controllogx, but it not directly read/write controllogix's tag, controllogix map tags...
4,618
117
