FactorySQL and FactoryPMI performance benchmarks available
surferb
Jun 2007
DC area
1,777
A number of posters have asked for hard numbers in terms of performance for tags stored in an SQL database and concurrent clients in FactorySQL and FactoryPMI.
Here's a summary of the results and the full whitepaper.
In a nutshell, FactoryPMI Gateway - With a small server, expect between 70-100 clients at a time, depending on the size of your project. With a large server, 150+.
FactorySQL - depends more on changing tags than total number. Systems with upwards of 250,000 tags are feasible, as long as only a small percentage of them are actively changing every second. Tag throughput for a low-end server or high-end desktop computer, ranged between 2,500, and 13,000 tag changes per second.
Hi. I have a relatively simple dataexhange between an OPC server and an Oracle database. This I have solved by means of VBS scripting. Problem...
5,746
who already used FactorySQL of InductiveAutomation, It same as RSSQL of AB? Link of this software...
3,529
For all the FactoryPMI users out there - the security certificates recently expired in the current version. This causes a warning message and...
1,570
One thing I found out is PMI does not have a realtime database engine. It solely relies on OPC tags for all data exchanges. The EXPRESSION inside...
6,351
Hi Does anyone have experience with FactoryPMI from "Inductive Automation" ?
2,724
