FactoryTalk ME Multistate button Disable
alexbeatle
Feb 2010
San Francisco
188
Good day, everyone!
I've got a multistate "Recipies" button that needs to be disabled when the process starts. I set it to invisible when start_tag=1. On top of the multistate button I placed a multistate indicator and it becomes visible when start_tag=1.
The indicator changes its visibility and appears on top of the button. However I can still press on the button (through the indicator) dispite the fact that the indicator is much bigger than the button.
Any suggestions?
Thank you,
Alex
That is most odd. I've done the same thing many times using animation visibility. What I'll often do is hide the button and make a mock button out of a panel and some text that appears to be the same button only 'grayed out' making it's visibility oposite of the buttons.
Temporarily move the indicator to the side slightly and verify that the button actually is invisible and not just hidden by the indicator.
Thank you. The button wasn't becoming invisible.
However, if I cover a momentary button without making it invisible, it cannot be pressed while covered. I guess the multistate buttons are programmed differently.
Thank you, all.
Hello, I have a few multistate indicators that I am using to represent what product is in the location that it represents. They are all identical...
1,890
Hi everyone! Need yor help. Normally we use Multistate Indicator for different values of ONE tag. But is it possible to use one Multistate...
6,674
Good Morning , I have a multistate pushbutton that I don't want to depend on the operator to press before leaving a screen. Is there a way...
2,983
Hi, Iam still struggling to get the multi state indicator in ftview me to work. I have two states, 0 and 1. Each state makes use of an image...
3,508
I'm converting a pva program to a mer in FactoryTalk View Studio ran into a addressing question.The multistate indicator in FT only gives me the...
4,541
