FactoryTalk SE and Page Up/Down Buttons
shutout31
Mar 2010
canada
I am trying to have multiple control List Selectors actuated/Functioned from one up and one down button to cycle scrolling. The output function of the Control List is only used on one however we are using multiple lists only for formatting purposes. I need to be able to point to each control list and send the function. Any suggestions either with XML or VBA?
There are several issues you have to solve:
a) Move Up and Move Down buttons only have effect over the object with focus or a linked object.
b) ControlListSelector object doesn't expose its methods to VBA. So there are no MoveUp or MoveDown methods.
c) You can select Type Info Extension on ExposeToVBA property and try to reach the ControlListSelector through Application.ActiveDisplay.Elements. But again it's a dead end.
d) The best approach is using SetElementFocus and SendKeys. Suppose you have two buttons and two ControListSelectors:
Code:
Private Sub btnUp_Released()[INDENT] Application.ActiveDisplay.SetElementFocus (FirstControlListname_here)
SendKeys "{Up}"
SendKeys "{Up}"
[/INDENT]End Sub
Private Sub btnDown_Released()[INDENT] Application.ActiveDisplay.SetElementFocus (SecondControlListname_here)
SendKeys "{Down}"
SendKeys "{Down}"
[/INDENT]End Sub
Of course, this code works if both ControlList objects are pointing to the same item.
Hello All, I've set the Alarm display to be "on top" whichever display is currently on whenever an alarm trigger occurs, this works well. But I...
1,716
I am needing to display a local svg file that is constantly updating within my runtime application. My file is located as...
3,323
Hi all, i know this seems to have been asked alot but i cant find a solution. I have an HMI application and it has no login for users, its an...
10,966
Hi, When comissioning engineers need to fine-tune parameters such as timers and some process tolerances and such-like, I sometimes have to...
7,210
Hello, I have a panelview plus that reads from 4 different PLC's. 2 of these used to be Micrologix PLC's and someone else went and updated them to...
74
