Factorytalk studio 12 help
stu
Aug 2005
England
785
Hi
I have a new laptop and with factorytalk studio v12
The issue that I have come across When I am setting up the communications for the screen I can't automatically pick up the iP addresses for the devices on the network , the only way I can do it is to add devices manually?
Has anyone had this before? Or know how I can get the ip address automatically thanks
Hey Stu,
In the project tree, at the very bottom of the tree there is a communication tab. Click it. Right click on the Ethernet driver and select properties. There should be a list of your network adapters. It often defaults to "Any". Select the adapter that has the address of the subnet you are communicating on. After Ok/close, you may have to right click on the driver and select start browsing.
Hey Stu,
Just wanted to throw out a Thank You for this. I have a new laptop with a VM (first time). When I downloaded a .mer file to the HMI I would get an error message about not being able to see my tags in the PLC. I could ping both machines OK from my laptop. As Dmroeder said, I went into the communications and 'Any' was selected. I had my VM to Windows 10 network connection and my laptop. I selected my laptop and everything working correctly.
Can someone support me with the Factory Talk View studio 10 download link? regards
3,734
hi guys I have just upgraded to ftv studio (ME) to version 10.0 from version 9.0 on a windows 7 64 bit laptop and now when I try and open a file...
1,703
I am having trouble with the expression editor setting up some colour change animation. I have a bool tag and an int tag. I will have four...
1,620
Hello everyone, I have a line that is currently running an older version SE local station application. I took a backup of it and "updated" it by...
6,063
Hi everyone, I've got a laptop that has windows 10(I didn't have a choice) and I'm trying to set up communications in view studio, every time I...
10,738
