FactoryTalk View I-O tags to bit level
beethoven_ii
Nov 2006
Central England
409
I'm working on a number of HMI projects just now using Factorytalk View ME V9 and I've come to map in my I-O onto the status pages of the screen and found that it no longer allows me to add I-O tags down to the bit level. Previously the tag browser would only go to 'Local:1:I.Data' level but it allowed you to manually add the .1 or whatever bit you needed at the end. If I do this now it doesn't work and the screen can't read the status of the bit.
I have come across this before on a project some months back and just I created aliases for the I-O tags. The project I'm working on now is much larger and I wondered if there was another way I could achieve what I need without creating endless arrays of alias tags in my plc?
Thanks for the reply.
That's exactly what I have been doing for years but now it doesn't seem to work. I can manually add the bit reference as I've always done but the screen doesn't read the tag when I connect it to the plc.
Are you sure you not doing something wrong.
It is working for me.
I have just quickly set it up with emulator and I can change a bit and it is changing animation on the HMI
Maybe you have module inhibited?
You are correct. I've tried it again and now it works. I started trying to do it on my Point I-O tags, not the Local I-O tags and must have selected the wrong option. The point I-O tags have a physical address and an alias which are automatically generated. I must have chosen the wrong one.
Thanks for your help
After having further problems with this I discovered the true cause of my confusion this morning. In my screen project I had referenced the tags for animation with slot numbers using Slot8_Input0 for example whereas the correct tag name should have been Slot_8_Input0. The additional underscore was my problem and not the software.
Hello, My apologies in advance if this is a stupid question. I have done a fair amount of work in Factorytalk View machine edition, and I am...
1,224
Hi guys! I want to read a tag name of hmi tag to create a generic alarm message. Do you know if it's possible to do? I'm using factorytalk view...
712
Hopefully someone that knows more about this stuff can help me...? Trying to add a visibility animation to a button, and my tag browser doesn't...
1,600
Hi - quick question. Can FactoryTalk View tags (HMI memory tags) be read via an OPC client ? I've setup a test FactoryTalk project with a couple...
2,404
Good Afternoon , I have a machine that has ControlLogix in it. It was done with RS Logix 5000 v.20.04 . The manuafacture used Windows XP to...
14,108
