FactoryTalk View SE 9.0 VBA
dsait
Dec 2016
edmonton
17
Morning Guys. I have been struggling to get a print screen to run reliably. I saw some posts about using a 3rd party print screen software. If this is the way to go can someone suggest the best one to go with. I am green to VB but have assembled the attached code. Any suggestions to make it cleaner are welcome. Sometimes the print screen works. Other times it will printscreen a different page. And lastly sometimes it locks up on the windows printscreen line.
Code:
Private Sub PrintDisplay_Change()
On Error GoTo errorhandler
    If Not IsError(PrintDisplay.Value) Then
        If PrintDisplay.Value = 1 Then
            ExecuteCommand ("display Something")
            Button1.Visible = False
            Button2.Visible = False
            BL_Zoom_Out.Visible = False
            BL_Zoom_In.Visible = False
            BL_Reset_PB.Visible = False
            BL_Pan_Newer.Visible = False
            BL_Pan_Older.Visible = False
            Application.LogDiagnosticsMessage ("Prepared for Something Downtime Trend PrintScreen")
            [COLOR="Magenta"]Windows.Application.SendKeys "(%{1068})" ' Windows Printscreen
            DoEvents[/COLOR]
            Application.LogDiagnosticsMessage ("Something PrintScreen Complete")
            Button1.Visible = True
            Button2.Visible = True
            BL_Zoom_Out.Visible = True
            BL_Zoom_In.Visible = True
            BL_Reset_PB.Visible = True
            BL_Pan_Newer.Visible = True
            BL_Pan_Older.Visible = True
            Dim objexcelapp As Object
            Dim fname As String
            Dim fsave As String
            Dim dblank As String
            'Create PDF
            fname = "BRG " & Format(Now, "mmm-dd-yyyy") & "      Time " & Format(Now, "hh-mm-ss")
            fsave = "c:\BackupReports\" & fname
            dblank = "c:\backupreports\VTR.xlsx"
            Set objexcel = CreateObject("excel.application")
            objexcel.Visible = True
            objexcel.Workbooks.Open (dblank)
            objexcel.ActiveSheet.Paste
            objexcel.ActiveSheet.PageSetup.PrintArea = "$a$1:$ae$52"
               With objexcel.ActiveSheet.PageSetup
                    .LeftMargin = objexcel.Application.InchesToPoints(0.25)
                    .RightMargin = objexcel.Application.InchesToPoints(0.25)
                    .TopMargin = objexcel.Application.InchesToPoints(0.5)
                    .BottomMargin = objexcel.Application.InchesToPoints(0.25)
                    .CenterHorizontally = True
                    .CenterVertically = True
                    .Orientation = xlLandscape
                    .Zoom = False
                    FitToPagesWide = False
                    FitToPagesTall = False
                End With
                objexcel.ActiveWorkbook.ExportAsFixedFormat Type:=xlTypePDF, _
                        Filename:=fname, _
                        quality:=x1qualitystandard, _
                        openafterpublish:=False
                        objexcel.ActiveWorkbook.SaveAs (fsave)
                        objexcel.Workbooks(fname).Close (False)
                        objexcel.Quit
                        Set objexcelapp = Nothing
            'Grab email list
            Dim ToList As String
            Dim EMB As String
            EMB = "C:\BackupReports\EmailList_Worksheet.xlsx"
            objexcel.Workbooks.Open (EMB)
            ToList = objexcel.Range("t55")
            objexcel.Workbooks("EmailList_Worksheet").Close (False)
            objexcel.Quit
            'Send Email
            Dim objapp As Object
            Dim objmail As Outlook.MailItem
            Set objapp = CreateObject("Outlook.Application")
            Set objmail = objapp.CreateItem(0)
            With objmail
                    .To = ""
                    .CC = ""
                    .BCC = ToList
                    .Subject = "Something"
                    .ReadReceiptRequested = False
                    .BodyFormat = olFormatHTML
                    .HTMLBody = "Automated Email"
                    .Attachments.Add fname & ".pdf"
                    .Save
                    .Send
                End With
            Set objapp = Nothing
            Set objmail = Nothing
            ExecuteCommand "display something"
            If something.Value = 1 Then
                ExecuteCommand ("display alarms_banner")
                End If
        End If
End If
Exit Sub
errorhandler:
LogDiagnosticsMessage Err.Number & " " & Err.Description, ftDiagSeverityError
End Sub
I'm creating an HMI that has a recipe with 288 data point. It has 3 pieces of data for 96 segments. I need help with VBA code to copy all 288...
143
Hi, Can someone guide me through how to use FactoryTalk SE VB script to open communication with SQL Server? which command I can use? Are there...
2,306
Hello group, I have been migrating a project from RSView 32 V7.6 to FactoryTalk View SE Local Station V12 over the last couple of days. All told...
1,000
For trend charts, I can use an ActiveX Calendar control to select a date on a trend using the following code where "Trend" is the name of the...
1,584
Anyone know how to change the mouse icon to something else using VBA? It looks like it can be done with VBA forms and based on the object the...
2,220
