FactoryTalk View SE + VBA help
cpriest
Aug 2008
Arizona
I have written some VBA to access a SQL database, display the information, and write it to tag values. The code works perfectly on the HMI server but does not work on the client. The error I'm receiving on the client computer is "Compile error: cannot find project or library". After researching, the only explanation I could come up with is to add/delete libraries in the VBA editor under Tools-->References. However, there is no development done on the client computers. We are currently running version 5 of FactoryTalk View SE (cpr9). Can anyone help? Thanks in advance.
I'm creating an HMI that has a recipe with 288 data point. It has 3 pieces of data for 96 segments. I need help with VBA code to copy all 288...
148
Hi, Can someone guide me through how to use FactoryTalk SE VB script to open communication with SQL Server? which command I can use? Are there...
2,306
Hello group, I have been migrating a project from RSView 32 V7.6 to FactoryTalk View SE Local Station V12 over the last couple of days. All told...
1,000
For trend charts, I can use an ActiveX Calendar control to select a date on a trend using the following code where "Trend" is the name of the...
1,586
Anyone know how to change the mouse icon to something else using VBA? It looks like it can be done with VBA forms and based on the object the...
2,222
