FactoryTalk View SE VBA Tags to Excel
I got where was problem. I written script in module, as i made it b4 in rsview 32. There is lot difference between rsview32 & ftview VB.
Now i want that how i can run VB at specific event in ftview se. IN rsview 32 i did that as added executevb in event. But here in ftview no option available to run VB. can u plz help me to how to run VB at specific event(tag ON bit)??
:unsure:
Option Explicit
Dim tkqt As New ADODB.Recordset
Dim MyTAgGroup1 As TagGroup
Dim t2tag As Tag 'tag object
Dim tkmeasuredQty As String
Dim t1tag As Tag 'tag object
Public Function tankerquantity()
ConnectDB
If MyTAgGroup1 Is Nothing Then
Set MyTAgGroup1 = Application.CreateTagGroup(Me.AreaName, 500)
End If
MyTAgGroup1.Add "system\second"
MyTAgGroup1.Add "SECTION1\TEST1"
Set tkqt = New ADODB.Recordset
With tkqt
.ActiveConnection = adodbcon
.CursorType = 2
.LockType = 2
.Source = "tblLTReport"
.Open
End With
tkqt.MoveLast
Set t1tag = MyTAgGroup1.Item("SECTION1\TEST1")
tkmeasuredQty = t1tag.VALUE
tkqt.Fields!MeasuredQty = tkmeasuredQty
tkqt.Update
End Function
this script is running fine. whether i need to change anything in this, or add anything else.. plz tell me.
also i want to ask that i used rslinx enterprise for communication. so i linked tags directly in graphics(tags not added in HMI tags). But in VB in needed HMI tags. So i want that whether i need to add all tags which i using in VB, in HMI tags. Or any other option is available to link tag in VB(without adding in HMI tags)?????
Sorry to ask all this.. i am new to FTVIEW & i dnt hav more support..
Option Explicit
ConnectDB
End If
With tkqt
.CursorType = 2
.LockType = 2
.Open
End With
tkqt.MoveLast
tkqt.Update
End Function
You can write script on Numeric Display Change.
Check this thread http://www.plctalk.net/qanda/showthread.php?t=45273
Convert Function to use with event
Is there any way that I can use this function in FTView event rather calling on NumericDispaly_Change?
Hi ghatevinod
You Can try Below Script with some modification such as save file path and tags.
Private Sub NumericInput5_Change()
Dim sFileName As String, sPath As String
If MyTagGroup Is Nothing Then
Set MyTagGroup = Application.CreateTagGroup(Me.AreaName)
MyTagGroup.Add "AI\I1"
MyTagGroup.Add "AI\I2"
MyTagGroup.Add "AI\I3"
MyTagGroup.Add "AI\I4"
' On Error GoTo ErrorHandler
Dim SourceErrFile, DestErrFile
Dim Tag1 As Tag
Dim Tag2 As Tag
Dim Tag3 As Tag
Dim Tag4 As Tag
Dim Mytime
'Set the tag objects
Set Tag1 = MyTagGroup.Item("AI\I1")
Set Tag2 = MyTagGroup.Item("AI\I2")
Set Tag3 = MyTagGroup.Item("AI\I3")
Set Tag4 = MyTagGroup.Item("AI\I4")
Excel.Application.Workbooks.Open "C:\resourcelibrary\import.csv"
Excel.Application.Visible = True
Cells(2, 4) = Tag1.Value
Cells(3, 4) = Tag2.Value
Cells(4, 4) = Tag3.Value
Cells(5, 4) = Tag4.Value
ChDir "C:\resourcelibrary"
ActiveWorkbook.SaveAs Filename:="C:\resourcelibrary\Import" & "-" & Format(Now, "dd-mmm-yyyy-hh-mm-ss") & ".xls"
Filename:="C:\resourcelibrary\Import.xls" & Date & " " & Time
ActiveWorkbook.Close
End If
End Sub
Thank you guys. Lots of new science in this forum.
Dear Bansodevb,
I need help in SE VBA Code. I got Code for PLC Forum that is working fine.Right Now I want Cells increment Code in vba. Please Help for me. I Have More than 250 Tag.
How to write for above Logic for BMS Application.
I attached that code below
Private Sub Button1_Released()
Dim ObjExcelApp As Object
Dim Fname As String
MyTagGroup.Add "AI\I5"
Dim Tag1 As Tag
Dim Tag2 As Tag
Dim Tag3 As Tag
Dim Mytime
Set Tag3 = MyTagGroup.Item("AI\I5")
Fname = "D:\Lord Shiva.xlsx" 'name of already created excel project
Set ObjExcelApp = CreateObject("Excel.Application")
ObjExcelApp.Visible = False
ObjExcelApp.Workbooks.Open (Fname)
ObjExcelApp.WorkSheets("Sheet1").cells(1, "A").Value = Tag1.Value
ObjExcelApp.WorkSheets("Sheet1").cells(1, "B").Value = Tag2.Value
ObjExcelApp.WorkSheets("Sheet1").cells(1, "C").Value = Tag3.Value
ObjExcelApp.ActiveWorkbook.SaveAs Filename:="D:\Lord Shiva" .xlsx"
ObjExcelApp.Workbooks.close
ObjExcelApp.Quit
Set ObjExcelApp = Nothing
Exit Sub
End Sub
Sir Im waiting for your reply
my mail id:[email protected]
Please send relevant cod my mail sir
Poderia me Ajudar??
Estou fazendo exatamente como seu codigo descrito abaixo:
Private Sub Button_AlarmAck1_Released()
If oGroup Is Nothing Then
Set oGroup = Application.CreateTagGroup(Me.AreaName, 500)
oGroup.Add "T1"
oGroup.Add "T2"
oGroup.Add "T3"
oGroup.Add "T4"
oGroup.Active = True
Dim Tag1 As Tag
Dim Tag2 As Tag
Dim Tag3 As Tag
Dim Tag4 As Tag
Dim Mytime
Set Tag1 = oGroup.Item("T1")
Set Tag2 = oGroup.Item("T2")
Set Tag3 = oGroup.Item("T3")
Set Tag4 = oGroup.Item("T4")
Excel.Application.Workbooks.Open "Z:\Pasta1.csv"
ChDir "D:\"
ActiveWorkbook.SaveAs Filename:="D:\Import" & "-" & Format(Now, "dd-mmm-yyyy-hh-mm-ss") & ".xls"
'Filename:="D:\Import.xls" & Date & " " & Time
End If
A linha ->Filename:="D:\Import.xls" & Date & " " & Time
esta me dando erro. Tenho meu excel numa outra maquina por isto da unidade Z:
Meu script esta certo para jogar um valor do supervisorio digitado para uma planilha excel???
My Portuguese is a bit rough, if the location doesn’t exist on the computer running the display client and you want to save it elsewhere you can reference the location with its UNC name:
ActiveWorkbook.SaveAs Filename:="\\mycomputer\d$\Import" & "-" & Format(Now, "dd-mmm-yyyy-hh-mm-ss") & ".xls"
Assuming you have a DNS server on your network and permissions to write to the location.
Hi NareshKusa, Thankyou for your code.I solved one of the requirement from ur code.
Hi NareshKusa,
Thankyou for your code.I have solved one of the process requirement from your(VBA to Excel) code.
Communication is good.But while execution,one dialog box opened & its showing Read/write access.Every time i have to close manually.is any update is there.
I need help with SE VBA code. I am using the VBA code in this forum but it is giving me a compile error: Sub or Function not defined at the tag values write into the cells of the excel spreadsheet. Can anyone please help me with this. I am using FTV SE V12. Below is the code
Private Sub NumericDisplay1_Change()
MyTagGroup.Add "CLEAN\Test_1"
MyTagGroup.Add "CLEAN\Test_2"
MyTagGroup.Add "CLEAN\Test_3"
MyTagGroup.Add "CLEAN\Test_4"
Dim Tag1 As Tag
Dim Tag2 As Tag
Dim Tag3 As Tag
Dim Tag4 As Tag
Dim Mytime
Set Tag1 = MyTagGroup.Item("CLEAN\Test_1")
Set Tag2 = MyTagGroup.Item("CLEAN\Test_2")
Set Tag3 = MyTagGroup.Item("CLEAN\Test_3")
Set Tag4 = MyTagGroup.Item("CLEAN\Test_4")
Cells(1, 1) = Tag1.Value
Cells(1, 2) = Tag2.Value
Cells(1, 3) = Tag3.Value
Cells(1, 4) = Tag4.Value
End If
End Sub
Try this:
Dim Fname As String
Dim Tag1 As Tag
Dim Tag2 As Tag
Dim Tag3 As Tag
Dim Tag4 As Tag
Fname = "C:\resourcelibrary\import.csv" 'name of already created excel project
ObjExcelApp.ActiveWorkbook.SaveAs Filename:="C:\resourcelibrary\import.csv.xlsx"
ObjExcelApp.Quit
End Sub
I'm creating an HMI that has a recipe with 288 data point. It has 3 pieces of data for 96 segments. I need help with VBA code to copy all 288...
142
Hi, Can someone guide me through how to use FactoryTalk SE VB script to open communication with SQL Server? which command I can use? Are there...
2,306
Hello group, I have been migrating a project from RSView 32 V7.6 to FactoryTalk View SE Local Station V12 over the last couple of days. All told...
1,000
For trend charts, I can use an ActiveX Calendar control to select a date on a trend using the following code where "Trend" is the name of the...
1,583
Anyone know how to change the mouse icon to something else using VBA? It looks like it can be done with VBA forms and based on the object the...
2,220
